05' Cummins bog
Old Apr 3, 2017 | 09:40 AM
5.9Cummins2005's Avatar
Default 05' Cummins bog
Hello, I have an 05' dodge cummins that I just replaced the lift pump in. After priming, the truck fired up nicely and I had it idling for about 10 min. I decided to take it for a test spin. Went for about 3 miles, stopped at a stop sign, and the truck bogged (but kept running) when I proceeded from the stop sign. Ok I thought maybe air. Kept goin (had it going 60 for a couple miles) slowed to pull back into my driveway and the truck bogged (still running) when I stepped on it in my driveway. Took it for another test spin, really stepped on it and she bogged right down. Came to a stop sign, SHUTDOWN. No start. Could this be air? Injectors? Cp3? IAT sensor? Any help is appreciated.
Old Apr 3, 2017 | 09:41 PM
CumminsCoalRoller24/7's Avatar
and check engine codes?
Old Apr 6, 2017 | 12:44 PM
davidthomas's Avatar
What lift pump did you put in? is there still the in-tank pump?
