Injector Fuel plate damage
i talked to the shop that did the machining and they said that the fuel plate was previously lapped too much so they had to take down the passage with a dremel..it was chatham fuel injection.btw. im not sure if this fuel plate caused the problem or not because i replaced the nozzle and the nozzle spring also. But basically the injector froze up at wot. And i belive the high pressure oil had nowhere to go and took out the solinoid.
