Stumped by ABS / brake light
Old Mar 31, 2017 | 04:51 PM
Noahs ark's Avatar
Default Stumped by ABS / brake light
Hey guys new here long time lurker.
2001 ram 2500 4x4 auto edge EZ everything else stock.
Last fall I replaced the front left hub. Yesterday the brake light and abs light come on.
I had replaced the abs sensor passenger side earlier in the year so figured I should get the shop to read codes. This is what I got.
engine - P1693 (companion module)
Trans - P0600 (speed signal) P1682 (voltage)
ABS - 25 (left front open ). 27 (left front intermittent) 74 (control mode timeout)
I had the shop dump all codes and none have come back since
Thinking all things pointing to front left sensor went home and had a look. The sensor wires rubbed right through on the dust shield as I plumbed it incorrectly first time.
I changed the front left sensor with a new one and the ABS light and brake light still on
Cruise control works speedo works all gauges functioning properly after doing the check with the trip odometer button. No brake pulsing when stopping.
HELP!
Old Mar 31, 2017 | 10:04 PM
Bryce's Avatar
Do you have rear drum brakes? I had the abs/brake light for a while until I adjusted the the rear drums and the parking brake. The light turned off and hasn't come back on. I don't have front abs sensors though.
Old Mar 31, 2017 | 11:09 PM
Noahs ark's Avatar
Yes it's rear drum brakes. Working fine and e brake aswell.
I should add. I find it odd that the lights came on the first time I started my truck after greasing the front end.
