Truck accerlation and bucking
Old Mar 18, 2017 | 02:17 AM
Graham Charbonneau's Avatar
Default Truck accerlation and bucking
So I just replaced all then injectors in the truck as they failed testing I'm still having issues. The truck wants to accerlate by itself and bucks like crazy under any throttle. It idles fine. I'm lost on what's happing. I attached a video. I get to speed then let go of the gas and this is the result
Old Mar 18, 2017 | 12:38 PM
CumminsCoalRoller24/7's Avatar
What CEL codes are being thrown?
Old Mar 18, 2017 | 02:38 PM
Gcharbs's Avatar
I pulled
P0217 decreased engine proformace due to engine overheat condition
P0192 fuel pressure sensor voltage too low
The engine tempature gauge never went above regular operating tempature however
Old Mar 18, 2017 | 08:02 PM
Originally Posted by Gcharbs
I pulled
I would check the following
1. Both battery connections and grounds
2. Fuel filter- make sure it is clean
3. Rail Pressure sensor connection (this is in the top of the fuel rail. Make sure it is dry and maybe use dielectric grease if possible)
4. Fan clutch connection- although gauge didn't get above warm check this- drivers side lower radiator. Seems like it could be an electrical thing...shocker.
Old Mar 22, 2017 | 12:31 AM
Gcharbs's Avatar
Okay battery terminals are tight and clean
There is a new fuel filter on it
It's an after market electric fan and it's running as it should be.
I took off the fuel pressure sensor harness and it was dry, I cleaned it anyways and put dielectric grease on it and now it runs worse than before.
Old Mar 29, 2017 | 05:26 PM
any progress?
Old Apr 1, 2017 | 04:31 AM
Gcharbs's Avatar
Originally Posted by CumminsCoalRoller24/7
any progress?
no none at all I'm stumped as what it could be
Old Apr 6, 2017 | 12:51 PM
davidthomas's Avatar
Check your apps, etc.
The APPS you can turn the key to on but don't start, push the accelerator all the down, and slowly let up on it and you will see the CEL flash several times to acknowledge the calibration.
