Can't figure out why my truck won't start, please help?
Old Feb 21, 2017 | 08:57 AM
Cbucci's Avatar
Default Can't figure out why my truck won't start, please help?
Hi all, I can't seem to get my 12v running, although it never really has ran well, it always had extensive cranking and little over it seemed.
I was taking the fuel play out, dropped one of the screws into the pump, tried to get it out with a magnet but couldn't, the truck say for maybe 3 or 4 moths before I had time to take the injector pump off. Once I took the pump off I had flipped it upside down shook it for a while until the screw came out. I timed the pump with Top Dead Center, put it all back together. (While the pump was off a friend of mine adjusted the "star" screw)
now that the trucks together, I primed it, possibly incorectly wouldn't start but it's pouring out clouds of white smoke.
I have replaced the unit inside the tank, all the fuellines, the lift pump, new filter, new WIF sensor, also cleaned out the filter right before the lift pump.
tried started it again, clouds of white smoke, I I adjusted the "star" screw down (now imy not sure how much the star screw should be adjust, or how much my friend turned it but I turned it way down)
now that I'm cranking over the motor, it's cranking over faster with no white smoke, turned the start screw up a little more, motor still cranking faster then it was with the smallest amount of white smoke
I don't know the it's the injectors or injector pump because it was running, I think maybe it's 150% airborne?
any ideas? I'm stumped.... thanks
Old Feb 21, 2017 | 03:00 PM
Just-Another-Dieselguy's Avatar
Your pump is out of time. You need to pin time the engine, and pin time the pump. Clean the shaft and gear really good with brake clean before tightening. Prime it, fire it up.
Old Feb 21, 2017 | 04:26 PM
JBearSVT's Avatar
I second this.
Old Feb 22, 2017 | 05:42 AM
Cbucci's Avatar
Maybe I pin timed the pump and motor wrong, but both pins were in place when I put the injector pump gear in place, everything was clean.
Could I just not be bleeding the air out of the fuel system correctly? What is the fuel bleeding procedure for this truck, I know the pump doesn't self bleed
Thanks guys
Old Feb 22, 2017 | 05:01 PM
JBearSVT's Avatar
It's also possible that your governor assembly is screwed up.
Old Feb 23, 2017 | 05:08 AM
Cbucci's Avatar
what is the governor assembly screw?
Old Feb 23, 2017 | 04:28 PM
JBearSVT's Avatar
OH! Hahaha. No, it isn't a screw. I meant the governor assembly could be damaged/worn out (i.e. "screwed up"). How many miles are on this engine?
Old Feb 23, 2017 | 05:44 PM
Cbucci's Avatar
The motor has 150,000 ish
Old Feb 23, 2017 | 07:11 PM
JBearSVT's Avatar
I suppose it's still a possibility, but I really don't think it's the governor assembly then.
