'98.5 PDC- Trailer Brake Wiring
Old Jan 4, 2017 | 10:25 AM
kerley's Avatar
Default '98.5 PDC- Trailer Brake Wiring
I'm having problems with the OME Dodge Ram 2500 Trailer Brake Wiring Harness. The previous owner removed the OME Trailer Brake Wiring Harness Connector, there are four color coded wires hanging there. I can't find the OME Connector anywhere if anyone has an extra, I will buy it. ALSO, Does Trailer Brake Hot- wire traverse through the PDC which would contain a 40 amp fuse and Brake Relay? If so what gauge Brake wire exits the PDC ? Everything I have read suggests installing a 10 gauge hot wire to the Brake wire connector at the rear of the truck. I can't find this information, possibly I am not looking in the proper place.
Thank you, Kerley
