2002 F350 7.3L Roaring behind dash after I shut engine down
Old Dec 15, 2016 | 09:21 AM
Tideman68's Avatar
Default 2002 F350 7.3L Roaring behind dash after I shut engine down
I have a 2002 F350 with 270,000 miles. I have a whirling/Roaring sound from behind the dash. It does not make this sound all the time. I noticed last night when I shut the engine down, for a few seconds there was a whirling/Roaring sound. Would this mean the Turbo needs to be replaced? What else would make that sound after the engine stops?
Old Dec 21, 2016 | 03:34 PM
Tideman68's Avatar
Default Ths is the sound
I have the sound attached it's at the end of the video after i turn the truck off.
Old Jan 10, 2017 | 09:28 PM
PowerStroker525's Avatar
Are you sure its behind the dash? Or is it under the hood? There is a vacuum pump under the hood on the passenger side that kicks on and acts wierd on my 2000 every once in a great while especially when cold
Old Jan 11, 2017 | 09:05 AM
Tideman68's Avatar
It is under the hood, but is sounds very close to the fire wall. I'll check that vacum pump you mentioned.
Thank you
Old Mar 23, 2017 | 01:07 PM
Tideman68's Avatar
turned out to be the Turbo.
