Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
Old Ford Solenoid as Glow plug relay for om617 / amateur in need of help
Old Dec 3, 2016 | 06:31 AM
DirtyxSocks's Avatar
Default Old Ford Solenoid as Glow plug relay for om617 / amateur in need of help
I'm trying to wire my glow plugs to a switch in cabin that will enable to turn on and off my glow plugs when I choose to with the flip of a switch.
I got the idea from a youtuber, he did similar work but he still had he original glow plug relay connected for the sensors
Anyhow I think I'm close to getting it done but I keep second guessing myself, and the last thing I want to do is burn out the glow plugs or burn out the solenoid.
Pictures:
A - 5 glow plugs wires (running from glow plugs to negative post)
B - brown Wire going to inside of cabin (running from starter post to inside of car)
C - green wire (connected to black thick gauge cable/to starter post on solenoid)
D - black thick gauge wire (to positive post on battery and on positive post solenoid)
Attached Thumbnails Old Ford Solenoid as Glow plug relay for om617 / amateur in need of help-image.jpeg
Old Dec 3, 2016 | 06:32 AM
Here's another
Old Dec 3, 2016 | 06:33 AM
And last one
Old Dec 3, 2016 | 06:35 AM
F and B are the same wire, and E is a ground inside cabin
