NO Start NO crank ZILCH
I hope you fellows can help. I have a 2000 7.3 auto that won't start. I can start it by jumping the solenoid on the passenger fender with a screwdriver. So its not the starter. I swapped out the ignition switch and still no go. I have power at the ignition switch but no power going to the solenoid when I try to crank it. I have tried to put a jumper on NS switch still nothing. I can put the key in and everything works as usual I get the WTS but when I try to go crank nothing. It doesn't even pull down the volts on the gauge. If I put the headlights on and try to crank it doesn't pull the lights down either.
anybody have any ideas? Can I jump the NS it looks like I should be able to pin 10 and 12. I was hoping to jump it to confirm its what I need.
Let me also say it clicks inside the cab. I have swapped all the relays around too.
Thanks
Thanks
