48RE Not Going into OD
Old Oct 30, 2016 | 05:29 PM
DaveAlex's Avatar
Default 48RE Not Going into OD
Symptom first occurred with the sudden loss of 3rd, Torque Lockup and OD. TIPM was changed by the Dodge dealer and that cured all but the OD issue. OD solenoid was then changed but did not fix it. Other forums have spoken to broken wires/bad connectors. I can' seem to find an accurate wiring diagram for my transmission to start the search. Can anyone offer any assistance?
Old Oct 30, 2016 | 06:44 PM
CumminsCoalRoller24/7's Avatar
I lost OD in my 48re a couple months ago - the OD connection is on the drivers side top of the trans toward the front. There are only a few wires that go into that connector, you can try and pull it out and add some dielectric grease. I was not lucky enough to have that fix mine. To clarify do you have 1-4 and then the converter is not locking for 55+ mph. When OD is engaged does the converter lock on that shift setting?
OD connector
You can try changing the output shaft speed sensor as well which is an easy swap and $25 part at a local advanced/oriley/autozone
Old Oct 30, 2016 | 07:25 PM
DaveAlex's Avatar
The torque converter is locking up fine in all gears. Shifts 1-3 are fine, just won't go into fourth at 55 (80klms) per hour.
About a year ago I had the 'shuttle shifting' problem and changing out the transducer and shift solenoid to those supplied by BD Diesel solved those problems. Tranny was running great until the sudden failure of the TIPM. When it failed I had ABS light on, Brake light on, no lock up, no 3rd or OD and engine light. New TIPM cured all but the OD (4th gear) issue. I have been told to chase a bad wire/connection (corrosion?) but I don't know where to start/look. Can't seem to find an accurate wiring diagram for my year///
Old Oct 30, 2016 | 07:45 PM
I didn't have to replace my TIPM but did lose OD like you are describing and it was due to the OD unit taking a dump- do you have a programmer or way to confirm the TIPM is demanding 4/ lock up? Only wiring I tried chasing before having mine overhauled and confirmed it was dead was the plug in the pic above or disconnecting the large wiring harness for the PCM and cleaning/adding grease there. Not sure the history of the trans but mine was working fine - down shifted out of OD and when I went to resume speed never engaged again
Old Oct 30, 2016 | 08:23 PM
DaveAlex's Avatar
Default Looking for OD wiring diagram
Thank you for the info. I will let the forum know the results of my troubleshooting. I do not own a programmer for the 48re. I will continue my search for a correct diagram.
Old Oct 31, 2016 | 09:09 AM
dangerous1965's Avatar
Your clutches are worn out causing the seal to over extend and fail and there you are!
Old Oct 31, 2016 | 05:11 PM
X2- my issue simply described!
