03 5.9 cummins 3500
Old Oct 22, 2016 | 08:04 PM
Dale Kaye's Avatar
Default 03 5.9 cummins 3500
hi I was driving down the highway when all of a sudden my truck started running rough and there was a plume of white smoke from the exhaust any ideas on what the problem could be? thanks
Old Oct 22, 2016 | 08:10 PM
Dale Kaye's Avatar
also I stopped the truck right away
Old Oct 22, 2016 | 08:33 PM
CumminsCoalRoller24/7's Avatar
Sounds like an injector issue- any codes?
Old Oct 22, 2016 | 08:40 PM
Dale Kaye's Avatar
no I haven't done anything yet. whats worst case scenario that it could?
Old Oct 23, 2016 | 01:38 PM
Worst case Is an injector body is cracked and you will need to find it and replace it. Often times depending on mileage on them it is best to replace them all. Cycle the key 3 times and see if there are any codes
Old Oct 23, 2016 | 07:23 PM
Dale Kaye's Avatar
so I started taking the injectors out today and it turns out I have a broken exhaust valve. its damaged the bottom of the injector and bent the push rod so next job is to take the head off and take a good look at whats happened.
