07 5.9 trouble code p2146
Old Jul 26, 2016 | 09:23 AM
Klindeman74's Avatar
Default 07 5.9 trouble code p2146
I was pulling my fifth wheel travel trailer up a steep incline and check engine light came on and I lost all power. I got it off the road and it would idle but not enough power to pull the trailer. I got it down and check engine light then went off and it ran perfect. In January I had the same problem. Only I got an additional code at that time of p0202 as well as the p2146. I've done my fair share of research and it seems to point towards the valve cover gasket harness as well as injector number 2. I've heard of people just changing the solenoid on the injector to correct this issue as it seems to be on the electrical side and not the mechanical side of the injector. So I'm wondering the pros opinion on if it would be okay if I just changed the solenoid on injector 2 along with the gasket harness? Is my thinking correct as far as that being on the electrical side and not the mechanical side of the injector? It seems if it was the mechanical side of the injector it would run bad and possibly not throw a code? Both times after it sat for a bit the problem corrected itself. But it's a risk I can't take pulling a trailer up that hill with my family I'm going to get killed. Thanks in advance for any help or advice.
Old Jul 26, 2016 | 09:05 PM
CumminsCoalRoller24/7's Avatar
Sounds like your on the right track- I would check connectors at wiring harness and unhook batteries to reset the truck- if you wanted to dig a little deeper then pull the valve cover and check connectors on injectors 1-3...seems like electrical issues (not shocked face)
Codes--->
P0016 Crankshaft/Camshaft Timing Misalignment/Out-of-Sync
P0071 Ambient Temperature Sensor Performance / Rationality
P0072 Ambient Temperature Sensor Low
P0073 Ambient Temperature Sensor High
P0088 Fuel Rail Pressure Too High
P0106 Manifold Absolute Pressure Sensor Performance / Rationality
P0107 Manifold Absolute Pressure Sensor Low
P0108 Manifold Absolute Pressure Sensor High
P0111 Intake Air / Charge Temperature Sensor Performance / Rationality
P0112 Intake Air / Charge Temperature Sensor Low
P0113 Intake Air / Charge Temperature Sensor High
P0116 Engine Coolant Temperature Sensor Performance / Rationality
P0117 Engine Coolant Temperature Sensor Low
P0118 Engine Coolant Temperature Sensor High
P0128 Cooling System Error / Thermostat Rationality
P0148 Fuel Delivery Error
P0169 Water-in-Fuel Detected For Too Long
P0192 Fuel Rail Pressure Sensor Low
P0193 Fuel Rail Pressure Sensor High
P0201 Fuel Injector 1 Circuit
P0202 Fuel Injector 2 Circuit
P0203 Fuel Injector 3 Circuit
P0204 Fuel Injector 4 Circuit
P0205 Fuel Injector 5 Circuit
P0206 Fuel Injector 6 Circuit
P0217 Coolant Temperature Too High
P0219 Engine Overspeed
P0234 Turbocharger Overboost Condition
P0236 Turbocharger Boost Pressure Sensor Performance / Rationality
P0237 Turbocharger Boost Pressure Sensor Low
P0238 Turbocharger Boost Pressure Sensor High
P0251 Injection Pump Fuel Valve Feedback
P0300 Multiple Cylinder Misfire
P0301 Cylinder 1 Misfire
P0302 Cylinder 2 Misfire
P0303 Cylinder 3 Misfire
P0304 Cylinder 4 Misfire
P0305 Cylinder 5 Misfire
P0306 Cylinder 6 Misfire
P0335 Crankshaft Position Sensor Circuit
P0336 Crankshaft Position Sensor Performance
P0337 Crankshaft Position Sensor Circuit Low
P0338 Crankshaft Position Sensor Circuit High
P0340 Camshaft Position Sensor Circuit
P0341 Camshaft Position Sensor Performance / Rationality
P0381 Wait-to-Start Lamp Inoperative
P0461 Fuel Level Sensor 1 Performance / Rationality
P0462 Fuel Level Sensor 1 Low
P0463 Fuel Level Sensor 1 High
P0477 Exhaust Pressure Control Relay Low
P0478 Exhaust Pressure Control Relay High
P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)
P0483 Cooling Fan Speed
P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1
P0514 Battery Temperature Sensor Performance / Rationality
P0516 Battery Temperature Sensor Low
P0517 Battery Temperature Sensor High
P0521 Oil Pressure Sensor Performance / Rationality
P0524 Oil Pressure Too Low
P0532 A/C Pressure Sensor Low
P0533 A/C Pressure Sensor High
P0541 Intake Air Heater Relay 1 Low
P0542 Intake Air Heater Relay 1 High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0572 Brake Switch 1 Low
P0573 Brake Switch 1 High
P0580 Speed Control Multiplexed Switch 1 Low
P0581 Speed Control Multiplexed Switch 1 High
P0602 Control Module Programming Error/NotProgrammed
P0604 Internal Control Module RAM Integrity Failure
P0606 Internal ECM Processor
P0607 ECU Internal Performance
P0622 Generator Field Control Circuit
P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low
P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High
P0630 VIN Not Programmed in PCM
P0633 SKIM Key Not Programmed in PCM
P0642 Sensor Reference Voltage 1 Circuit Low
P0643 Sensor Reference Voltage 1 Circuit High
P0646 A/C Clutch Relay Circuit Low
P0647 A/C Clutch Relay Circuit High
P0652 Sensor Reference Voltage 2 Circuit Low
P0653 Sensor Reference Voltage 2 Circuit High
P0698 Sensor Reference Voltage 3 Circuit Low
P0699 Sensor Reference Voltage 3 Circuit High
P0700 Transmission Control System (MIL Request)
P0837 Four Wheel Drive (4WD) Switch Performance / Rationality
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P1652 J1850 Communication Bus
P2121 Pedal Position Sensor 1 Performance / Rationality
P2122 Pedal Position Sensor 1 Low
P2123 Pedal Position Sensor 1 High
P2127 Pedal Validation Switch 2 Low
P2128 Pedal Validation Switch 2 High
P2146 Fuel Injector Group 1 Supply Voltage Circuit
P2149 Fuel Injector Group 2 Supply Voltage Circuit
P2266 Water in Fuel Sensor Circuit Low
P2269 Water in Fuel Condition
P2502 Charging System Output Voltage
P2503 Charging System Output Low
P2504 Charging System Output High
P2509 ECM/PCM Power Input Signal Intermittent
P2607 Intake Air Heater Relay 2 Low
P2608 Intake Air Heater Relay 2 High
P2609 Intake Air Heater System Performance
Old Jul 26, 2016 | 09:57 PM
Yeah that's a good idea. When I get the valve cover off I'll check one through three. I guess the resistance should be between 0 and 1?
Old Jul 27, 2016 | 09:01 AM
Correct- depending how sensitive your meter is- anything more than 1.2ohms will throw the CEL/cause issues
Old Jul 27, 2016 | 11:10 PM
11B/11C's Avatar
also ohm your injectors as well. here is a factory service manual where you can get that info. https://www.dropbox.com/sh/81mtpw6h2...dZOLxp5ja?dl=0
