7.3 injector question
Old Jul 20, 2016 | 04:57 PM
davidgman's Avatar
Default 7.3 injector question
thinking of upgrading my fuel system how much psi can stock injectors take?
Old Jul 22, 2016 | 10:53 AM
joebob3093's Avatar
Moderator
not sure i understand what you are asking
Old Jul 31, 2016 | 01:30 PM
davidgman's Avatar
If i get a more powerful fuel pump and adjustable psi regulator how much should i turn it up before it gets to hard on the injectors?
Old Jul 31, 2016 | 08:06 PM
joebob3093's Avatar
Moderator
turning up the fuel pressure or adding a bigger pump will do 0 for more power
Old Aug 2, 2016 | 10:22 AM
davidgman's Avatar
need bigger injectornozzles ?
Old Aug 2, 2016 | 05:34 PM
joebob3093's Avatar
Moderator
Nozzles will also do nothing for power. They will just make it smokey and run hot. These have an injector and not nozzles like a cummins does. You will need a chip and injectors of you want me power.
Old Aug 2, 2016 | 07:54 PM
davidgman's Avatar
ya already have a superchip might upgrade to a bullydog and get a stack and an intake thanks man
Old Aug 3, 2016 | 08:11 AM
joebob3093's Avatar
Moderator
That would not be an upgrade. If you want an upgrade you need to get a hydra. Get the exhaust and of your choice and make sure you have gauges.
Old Aug 4, 2016 | 09:51 AM
davidgman's Avatar
wouldnt it ? Ithought the bullydog chips had better tunes? whats a hydra?
Old Aug 4, 2016 | 10:44 AM
joebob3093's Avatar
Moderator
The are no better then what you have now. The hydra is a chip built by power hungry performance. It allows you to add and remove custom tunes and shift on the fly. It is the best on the market for the 7.3.
