Lb7 aftermarket intake question
Old Jun 23, 2016 | 08:53 AM
Farmboylb7's Avatar
Default Lb7 aftermarket intake question
Hello, I am new to this forum and am looking for some advice. I have a 2004 lb7 duramax, all stock other than EFI live, intake horn and exhaust. I recently had my turbo rebuilt and had a batmowheel installed, along with the PPE boost valve. My question is: Is it safe to have a cold air intake on a truck that drives I'd say 70% of the time on dust gravel? Which brand of intake would be best for my application? I have to ask because with my factory intake box, I can tell that the turbo struggles to pull air through the factory filter (it pops the service filter button when it makes more than 24 lbs of boost) so I want to have more air flow, but I still need good filtration. Any help is appreciated!
Old Jun 25, 2016 | 07:07 PM
wyoranch's Avatar
Yes, they filter better and flow better than factory. The oil helps grab dust. Will probably need to be serviced every couple months if really dusty. I only buy s&b. Cheaper than most and perfect fit, high quality
Old Jun 25, 2016 | 07:12 PM
Farmboylb7's Avatar
Have you had any problems with the oil messing with the MAF sensor?
Old Jun 25, 2016 | 07:15 PM
wyoranch's Avatar
No, had them on probably 5 trucks. Currently have one on my duramax and one on my 97 dodge crew cab. The only way you'll have a problem is if you over oil it when you service it
Old Jun 25, 2016 | 07:16 PM
wyoranch's Avatar
The 06 in my sig had an afe because I bought it with one. It was more expensive and worked fine but not as nice looking as an s&b
Old Jun 25, 2016 | 07:18 PM
Farmboylb7's Avatar
Ah ok, thanks for the help! I will check out s&b intakes.
