Diesel knock 7.3 idi
Old Jun 13, 2016 | 02:40 PM
tommyboy8072002's Avatar
Default Diesel knock 7.3 idi
Hi everyone. I am having trouble trying to figure out what would cause this motor to knock. 93 ford 7.3 Idi. This motor has 97000.00 miles. Motor sat for a year or 2. After I installed this motor never made a single noise. Till a month later. Then made a nock noise. I thought it might be bad injectors. Opened the injectors one at à time noise was still there. pulled the valve cover on the passenger side valves seem to be OK and working fine. Just wondering if this is a bad motor. motor runs good . This motor did come out of an ambulance so I did change some things I also used the old wiring harness. There is a module on the throttle housing that I couldn't use I also had to use my old flywheel. The ambulance was an automatic and the truck that I put the motor in is a standard 5 speed. I am not sure if this is normal.
Here is the link to the video of the knock
https://m.youtube.com/watch?v=LOUnVnxK7cQ
Old Jun 13, 2016 | 10:10 PM
I forgot to add when the motor is running at hi rpm it goes away here is another video.
https://m.youtube.com/watch?v=_YfB_0AZDT0
