Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
DT466E Injector upgrade to DT530 HELP ASAP
Old Apr 7, 2016 | 04:27 PM
bkoso85's Avatar
Default DT466E Injector upgrade to DT530 HELP ASAP
Hey guys,
Hope I can get advice here quick. I have a 1997 International 4700 tow truck that I just did a full in frame rebuild on. I wanted to upgrade the injectors to the DT530E since I saw that on this site.
I got these injectors: Part # - EX63814BJ - Delphi from O'Reilly since they had the best deal and my shop works direct with them. I went off of OEM part number 1836250C1 to get these.
Comparing them side by side with my factory ones they look the same except for they are a tad longer. I attached a couple pictures. I can feel it bottom out in the injector cup. And I can get the hold down bolts in.
Attached Thumbnails DT466E Injector upgrade to DT530 HELP ASAP-20160407_142227.jpg   DT466E Injector upgrade to DT530 HELP ASAP-20160407_130212.jpg   DT466E Injector upgrade to DT530 HELP ASAP-20160407_130152.jpg
Old Apr 7, 2016 | 07:38 PM
nevrenufhp's Avatar
A BJ injector wont run right. They are a split shot injector, and yours is single shot. You need a BD body code.
Old Apr 8, 2016 | 11:29 AM
bkoso85's Avatar
Thank you for your reply.
Do you know of any good place to get some performance injectors for my truck? My truck is 210HP so i'm thinking the 250 HP ones would be a good gain. Would these work?
Anyone hear of this place?
https://swampsdiesel.com/products/in...international/
Old Apr 9, 2016 | 09:31 AM
nevrenufhp's Avatar
For sure. Those guys know the E injectors real well. Tell them what you want,and they can make it happen(within reason). Best place in the country for a 95-97 466/530E(single shot with 3 computers). I have worked with them before on a few similar builds.
The only other way to get past 350hp is to swap to a mechanical 466/530. Then your power is limited by your wallet.
