Should all injectors fire when key is on truck not running?
Old Apr 6, 2016 | 05:02 PM
Deerich2378's Avatar
Default Should all injectors fire when key is on truck not running?
I need help
Old Apr 7, 2016 | 02:26 AM
11B/11C's Avatar
zero injectors will be firing then. they wont fire till they see a specific amount of pressure. i think its around 5 kpsi
Old Apr 7, 2016 | 02:43 AM
So what does it mean when i have two firing with ignition on only
Old Apr 7, 2016 | 07:45 AM
dangerous1965's Avatar
You mean when cranking right? If the injectors are firing with the key on not running your ECM is fryed! Replace the harness, check the plugs to the harness?!
Old Apr 7, 2016 | 09:06 AM
Afraid of that
Old Apr 7, 2016 | 10:42 AM
Are u 100% injectors on a 03 5.9 diesel never fire without rotation of motor?
Old Apr 7, 2016 | 10:41 PM
11B/11C's Avatar
The injectors wont fire unless they have enough fuel pressure. The cp3 won't make any fuel pressure when the engine is not running. Do you think yours are firing?
Old Apr 17, 2016 | 10:52 AM
cerberus60's Avatar
Not true. With the engine not running or starter engaged and the key on, injectors #1 and #6 will cycle constantly to bleed the pressure out of the rail. ECU programming controls that.
Old Apr 17, 2016 | 02:26 PM
11B/11C's Avatar
how is there rail pressure if the truck hasnt been started? not fully understanding what you are saying here
Old Apr 17, 2016 | 02:57 PM
cerberus60's Avatar
Pressure will hold in the rail when the engine is shut down and the injector solenoid does not cycle. Keeps the potential for air getting into the system lower. When the key on sequence is detected the ECU cycles 1 injector on each bank.
When the cranking circuit is engaged there is a timeout that stops injectors cycling so the rail pressure can build. It takes 2 full engine revolutions to synch the cam and crank sensor so the CP-3 is spinning 3 times as many to build pressure. The purge routine is easily fit into the crank and synch before the engine actually fires.
