Sluggish 99 F-450 Throwing Codes
Old Mar 5, 2016 | 06:17 PM
zmatalucci's Avatar
Default Sluggish 99 F-450 Throwing Codes
Hello,
I have a late 99 F-450 that is very sluggish off the get go. I plugged a scanner into it and got the following codes.
P1280, P1119, P0500, P1247
I've done a lot of research in the archives, but still can't get my answer. I know the P1280 is most likely the ICP sensor, but could one code make it throw the others?
I've cleaned the fuel tank, injectors, up pipes, fuel filter, etc. and am about to drive off a cliff.
Old Mar 10, 2016 | 08:31 PM
Jamesplumbing06's Avatar
What's the air doing? Turbo spooling? Smoke ? Unplug map sensor. If it takes off.? Replace it. Looking at motor above evaporator coil for a/c on a small mount by itself with a vacumm line coming into bottom. Then YouTube diesel Ron and search exhaust sensor cleaning. Make sure she breathes and the computer knows she breathing well.
