94 cummins NO BRAKES
Old Feb 23, 2016 | 10:33 AM
Trevor Nystrom's Avatar
Default 94 cummins NO BRAKES
hey guys,
Ive got a 94 cummins with auto, 4x4 abs.
Last night I was driving along and hit the brakes pretty hard, truck stopped perfectly. After that I kept driving and went to take the next turn, hit the brakes, went right to the floor!!! uh ohhh, got out of the truck to see if there was any leaks/blown brake lines. Nothing. Its quite strange, when I depress the pedal it goes down then almost catches then goes the rest the way down. Alllllll the way at the bottom I can get them to work a little bit, but only once. will barley keep the truck stopped when I put it in drive.
I have been having some brake issues, ABS hasn't worked in awhile, rear brakes like to lock up when applied pretty hard. It does have fluid.
Another strange symptom is that when I press the pedal with the heater on, it changes the sound of the heater and makes it stop blowing....
I had to drive 30 miles to work today! scary scary. I do work at a tractor shop with all the tools I need, so hopefully I can get some input on what I should try doing. I am very mechanically inclined, but don't have much experience with brakes.
Thanks for all future help guys!
Old Feb 23, 2016 | 04:46 PM
No one got any suggestions?!
Old Feb 24, 2016 | 02:11 PM
j johnson's Avatar
sounds like master cylcnder is by passing its self i would start there
Old Feb 25, 2016 | 10:55 AM
Found the problem. Feel pretty dumb LOL.
Broken line on front passenger side.
Found this after replacing master cyl, and booster.
