06 radiator removal
Old Feb 21, 2016 | 08:50 PM
purplepuller's Avatar
Default 06 radiator removal
How hard is it to take out radiator on a 06. Searched around on web really couldn't find anything useful.
Old Feb 26, 2016 | 10:05 AM
dangerous1965's Avatar
Easy! remove hoses, remove plastic insert between rad and fan shroud, remove bolts of course! There are two on the plastic insert and two on the radiator upper support.
Pull up wiggle **** to side and get it out!
Old Feb 26, 2016 | 12:22 PM
gunman41mag's Avatar
Moderator
Old Feb 28, 2016 | 12:29 PM
Hey Thanks for info. Just come up from garage to get some lunch. Had a bad noise in front of engine. Changed water pump and tensioner and new belt. Still had the same noise, so tore into yesterday and found fan hub bearing was bad. Switched out bearing and new fan clutch. Also did the little hose under exhaust manifold. Will finish up putting it back together this afternoon.
