Old Feb 18, 2016 | 03:27 PM
MasterOfPuppets's Avatar
Default Newbie
Hey guys I'm new and I don't have a diesel yet but I've been looking at a few lately. The most predominate one that sticks out to me in my area is a 2006 Mega Cab Ram 2500. It has 120k miles on it and everything is stock except a CAI and a leveling kit with aftermarket rims. The owner has only owned it 3 months after buying it from another person and is not sure if the injectors have been replaced or not. Should I go through with this one or keep looking?
Old Feb 18, 2016 | 10:24 PM
11B/11C's Avatar
how does it run? does it have blow by? is there smoke coming out of the exhaust when the engine is hot or cold? does it smell like there is fuel in the oil?
Old Feb 18, 2016 | 11:50 PM
Runs like it's brand new. No blow by. No smoke. No different smell. The truck runs and looks brand new.
Old Feb 19, 2016 | 04:37 PM
CumminsCoalRoller24/7's Avatar
Well the biggest question is......how much? If it ran like do do but the price was right I'd say buy it!
Old Feb 19, 2016 | 04:45 PM
Its blue book and nada value is 31k they want 27k for it
Old Feb 21, 2016 | 11:38 AM
AHolt's Avatar
Check everything on front end, steering box an all parts.
They wear and are expensive to replace.
They are asking top dollar, I would not pay that figuring you will need to do
some work, 9 yr old truck.
Old Feb 21, 2016 | 11:57 AM
A little bit has been done already. HVAC was redone with a metal blend door and motor. There's a new steering stabilizer on the front new suspension put on with the leveling kit. Tires has 8k miles on them. As for the rest of the front haven't asked and there isn't any receipts so I assume nothing else.
Old Feb 26, 2016 | 08:05 PM
Jcummins1's Avatar
second the front end note. check all the rubbers make sure they're not dry rotted being a 06 it should of had the tie rod recall but look at the track bar bushings and such. steering stabilizers don't really do much in my opinion except make the steering harder. in my opinion 27k is way to much for 120k but prices might be different in your area. check the front 4wd drive line make sure the slip joint doesn't have much up and down play (not a big deal a new drive lines $300 or so) i wouldn't worry about injectors if it doesn't have a miss there was a recall on 06 injectors so it doesn't have 120k on the injectors. good luck and have fun
