oil filter adapter on Kubota
Old Feb 12, 2016 | 08:33 AM
Freedom92's Avatar
Default oil filter adapter on Kubota
I've seen some of you with a spin on remote adapter for the v2203. I have the long carrier type filter running along the block. I need to either point the filter perpendicular in relation to the engine or remote mount my filter which is what I prefer. I can't seem to find an adapter with the same size threading as the Kubota whit I believe is 1" x 16.
Old Feb 12, 2016 | 11:31 AM
dieselxj's Avatar
no extra parts needed for this style install. you just take off the elbow. you can also leave the elbow on and rotate the housing so the filter faces down.
I would have thought it would be pretty easy to find a remote filter adapter, I think the boss size is the same as a dodge cummins
have fun
Old Feb 12, 2016 | 12:04 PM
Freedom92's Avatar
I'm actually OK with that arrangement so long as it clears the frame rails. The remotes are cool but not a "have to" situation yet. Thanks for the info xj
Old Feb 12, 2016 | 12:20 PM
dieselxj's Avatar
if you are far enough along to be figuring oil filters,, how about some pictures and a build thread. I forget what vehicle did you pick?
I found 3 different length filters that fit the Kubota size, there might be one even stubbier than mine,
Old Feb 12, 2016 | 11:57 PM
Freedom92's Avatar
I have a 1999 Ford Ranger...3.0 auto 4x4. I am taking pics and will start a build thread soon. Kinda wand it to look good under the hood since I'm going through the trouble I thought I would doll it up a bit with aluminum and stainless hoses and parts. I've had trouble matching threads on fittings but im about to get the turbo and alternator/vac pump plumbed. I'll post pics of the motor on the stand...when I figure out how
