1992 D250 won't turn over
Old Jan 19, 2016 | 07:24 PM
dieselnut8492's Avatar
Default 1992 D250 won't turn over
The truck won't crank. Thought it was ignition switch. So I installed a push button start. Ran a wire on big terminal on starter and one on small through a switch. When I push button it makes one click and that's it. When I jump terminals with a screwdriver it fires right up. I only used like 18 gauge wire. Does it need to be thicker wire?
Old Jan 21, 2016 | 07:02 AM
blackduck's Avatar
By jump the terminals do you mean the positive to the small terminal or across the starter large terminals?
If large to small then possibly too small a cable on the push button circuit.
If across the starter terminals it sounds like a dodgy solenoid
