Excessive Blow By
Old Nov 2, 2015 | 04:04 PM
Jsk8ter5's Avatar
Default Excessive Blow By
If I have excessive blow by through the oil cap when I take it off. Can this be fixed by replacing all of the injectors? I also have white smoke coming out of the exhaust indicating an injector problem. I have replaced 3 and it seems that the truck runs better but should I keep replacing them or should I just trade the truck for another cummins?
Old Nov 2, 2015 | 06:30 PM
Bigg Redd's Avatar
Too much blow-by is an indication of worn or broken ring(s), even cylinder distortion will cause that. Oh even really worn valve guides. How many miles on that rig?
Old Nov 2, 2015 | 06:47 PM
Jsk8ter5's Avatar
So you can't wash cylinders with too much fuel and get excessive blow by? And it has 236000
Old Nov 3, 2015 | 08:49 AM
Bigg Redd's Avatar
Too much fuel will create ALOT of heat and burn a hole(s) in your piston(s). 236k really isn't a lot of miles for a cummins, really poor maintenance and abuse will have an affect on longevity. Also a poor quality air filter can allow dust particles to enter your engine and cause excessive cylinder wear, contributing to blow-by. If it were me, I would go for a rebuild.
Old Nov 3, 2015 | 10:49 PM
dangerous1965's Avatar
X2 your done! Come on down get in line 6700 installed! I'm doing one a month fun on the side! takes 3 days if your not in a hurry 2 if you are!
Old Nov 4, 2015 | 10:02 AM
Jsk8ter5's Avatar
What all would I have to be rebuild? Could I just put a set of rings in it and deglaze the cylinders? Because it doesn't really have any piston slap or rod knock or anything like that yet
Old Nov 4, 2015 | 04:51 PM
Bigg Redd's Avatar
You wont really know until the engine is torn down. smart money is on boring the cylinders, new rings, complete valve job etc. Ya really cant go wrong with a rebuild b/c that way you know your engine is fresh with no miles, and you will have piece of mind knowing that it is fresh. If ya bought another pre-owned cummins, you wont really know how that rig was treated, or if it was sold/traded-in due to mechanical issues or other problem(s).You may end up in the same situation that youre in now...or worse. Ya don't really know what youre gonna get. Its really a crap-shoot. If youre happy with your rig, and its been good to you, I personally would go with the rebuild. Its also cheaper than a new truck. But, its really up to you ultimately have to live with your decision. Cheers!
Old Nov 4, 2015 | 05:53 PM
Jsk8ter5's Avatar
Would you go with just any set of rings like some I could buy on rock auto? I
only plan on doing minor performance and would I need to do certain head studs or just factory? And any certain head gaskets?
Old Nov 4, 2015 | 06:56 PM
Bigg Redd's Avatar
That depends what you plan to do with your rig such as race, sled pull, mild performance or just stock..ish. Stick with cummins parts, but you cant go wrong with studs for possible future "upgrades" (if ya get my drift). Im using ARP's in my rig, but my mods are rather conservative, as my goal was only to increase efficiency.
If this is your daily driver, then I wouldn't go crazy with it. Mild performance is more than plenty for. But if youre into rolling serious coal, creating tire smoke screens that would rival the military's best efforts, and blowing the doors off mustangs, vettes, vipers, then the sky and wallet is the limit. (not quite sure I answered your question)
Old Nov 4, 2015 | 09:29 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
you might be able just bead hone cyls and new rings. never know till its tore down. we sell a lot of our mighty diesel head bolts. its going on 2 thousand sets across the country. i have them in my 97 sled pulling truck and my 08.
