Cummins 12V in my Chevy 1983 C30
Old Oct 26, 2015 | 07:06 PM
Choppycam's Avatar
Default Cummins 12V in my Chevy 1983 C30
Hello guy!
Recently, I have bough an COMPLETE 1990 Ramcharger D350 with a Cummins, 5 speeds. I want swap all is mecanic in my Chevy.
But for now, I'm looking for information and advice to help me.
My C30 2x4 have an slow stock 6.2. Recently I have found 3 cracks in the engine block on the passager side. I have already do a lot of work on this truck on the drivetrain:
- New rear brake, drum, show, spring, parking cable, wheel cylinder, hoses
- New rear wheel bearing on both side
- New clutch, pressure plate, pilot bearing, release bearing
- New 6.5 swap starter
- New engine oil pan gasket to.
- New power steering pump with all new steering and hydro-boost brake hose
I refreshed transmission and diff oils, rework front brakes...
So, now I will go with a Cummins 12V and need advice from guys who do this swap before.
Let me know if it already have an subject here that can help me.
The exact project is: swap 12V CUmmins with Getrag 2x4 in a dually C30 (2x4) 1983 DUMP TRUCK. The Getrag is good enough for my use... but need synchro on third... and new shim...
- No A/C installation
- don't need to follow federal restriction, we don't have any control here.
For now,
What I know:
1. I can re-use my chevy power steering reservoir directly on the dodge one.
2. I know existe engine mount for this swap on internet
3. I know I have to short or lenght the driveshaft and relocate the transmission member
What I need to know:
1. will I need body lift to fit this engine?
2. will I need modify frame somewhere?
3. will I need re-enforce front suspension? I know there some weigth difference between Cummins and 6.2
What I absolutely have to do:
1. Fix the KDP (killer dowel pin)!!!
Here some pics of my trucks:
Old Oct 26, 2015 | 07:20 PM
Choppycam's Avatar
Some pic after few hours of work on the truck ( around 200 hours )
Attached Thumbnails Cummins 12V in my Chevy 1983 C30-img_20140624_160336.jpg   Cummins 12V in my Chevy 1983 C30-img_20140701_150439.jpg   Cummins 12V in my Chevy 1983 C30-img_20140913_111844.jpg   Cummins 12V in my Chevy 1983 C30-img_20140713_143132.jpg   Cummins 12V in my Chevy 1983 C30-img_20140907_203653.jpg
Old Oct 26, 2015 | 07:23 PM
Choppycam's Avatar
some others and finaly pics on donator: DOdge
Attached Thumbnails Cummins 12V in my Chevy 1983 C30-img_20141005_153857.jpg   Cummins 12V in my Chevy 1983 C30-11202101_991904334153055_8704811740298530398_n.jpg   Cummins 12V in my Chevy 1983 C30-11418907_985026511507504_3017681606490989555_n.jpg   Cummins 12V in my Chevy 1983 C30-12063810_1053194198024068_6738464722383300605_n.jpg   Cummins 12V in my Chevy 1983 C30-12063471_1053194134690741_6040666790535559002_n.jpg
Old Oct 30, 2015 | 01:36 PM
u2slow's Avatar
The Chevy 1-ton suspension and frame is stronger than the Dodge. You may want heavier coil springs, but I would try what you have first.
Body lift helps (from what I've heard). At least you only have you do the cab (not the dump). I had 2" body lift in a crewcab like yours, and I liked the result.
Old Oct 31, 2015 | 11:18 AM
Choppycam's Avatar
Thanks for your answer
I think you right. 2'' body lift could look better. I will consider this. Anyway, I project to paint the cab, so remove it. It will be a good moment to lift it.
About front suspension and frame, it's a good think to know that chevy one are stronger then I aspect. I will try with the original coil spring. If it doesnt work, I will try with a pair on AIR SHOCK that I sell at NAPA auto part.
Do you have a picture of your truck with 2'' lift?
Old Nov 1, 2015 | 01:11 AM
u2slow's Avatar
It was a '91 V3500 ex-logging crummy...
Old Nov 4, 2015 | 07:57 PM
Choppycam's Avatar
AAAH!!! Look awesome. I thinking about tool box for each side of my flat bed.
