7.3 running issue
Old Sep 29, 2015 | 10:56 AM
Powerstroke36's Avatar
Default 7.3 running issue
I recently took my truck on a trip, where I got almost back home and it had a miss as a gasoline engine would when the distributer caps go bad. Then the next day, i had just crank it up to move it about and in 300 feet and it just cut off on me. It fired right back up. Does anyone know what this could be?
Thanks!
Old Sep 29, 2015 | 07:05 PM
cjt8569's Avatar
If it's a 99-2003 7.3 try the cps cam position sensor located on the front right side of motor directly on top of hominid balancer 1 10mm bolt that's holds it in... Symptoms running fine then just die wait a few seconds fires up drives then dies again could be 1 foot or 10 miles before it does it again
Old Sep 29, 2015 | 07:16 PM
cjt8569's Avatar
Also try the valve cover gasket that has all the electronics for the injectors and glow plugs seen them burn out case skips but if it's like an injector skip try some regular ATF or Sea Foam in the fuel tank on your next fill up it cleans the injectors see if it gets better
kevin krehel
18
May 14, 2015 05:07 PM
Rbear
May 3, 2015 07:47 PM
Msc
Apr 23, 2015 06:21 PM
1997fordf350
Jan 15, 2015 06:12 PM
UniqueCopy
Dec 14, 2014 11:37 AM
