Chevy/GMC Duramax 07.5 -10 LMM Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines
'10 Duramax Fuel Issue
Old Sep 9, 2015 | 09:14 PM
Diesel_Daddy6.0's Avatar
Default '10 Duramax Fuel Issue
I am in the military and we have a newer maintenance truck, '10 Silverado 6.6 Duramax, with 10k miles on it that is having a starting issue. The truck is bone stock and cranks good and strong, just replaced the fuel/water separator and fuel squirts out when the bleeder screw on the filter housing is opened. Also, the O-rings on the F/W separator are seated and the WIF sensor appears to be in good shape as well as the fuel head. The truck was on its way back from the field when it died out so I don't believe the notorious WIF sensor crack happened randomly while driving.
We have not discovered any leaks anywhere in the system, however it will only start after we pump up the primer until it is firm and only idles for a second before dying, but that pressure will leak down if left for a few minutes. We do not have the equipment to perform tests other than a dinky scan tool to check for DTCs. I would prefer to not tear down the top half of the motor to get down to the injection pump if we don't have to. Any parts that need to be replaced will have to be approved through the command's supply department before being able to be purchased from the stealership. This process can take a couple weeks so just throwing parts at the truck that are not the problem can easily turn into months before the truck is running again. This is our only field service truck so the sooner we can get it up and running, the better. We do have an '08 that is currently down due to Chevy's recent airbag recall and linkages for the driver door handles but otherwise runs fine, is there anything on that truck that we might be able to use to diagnose the issue? Any insight that anyone can provide would be greatly appreciated.
Old Nov 12, 2015 | 09:33 PM
2004LB7's Avatar
not sure if you got this resolved yet but if not, try replacing the fuel line coming out of the filter housing with a clear hose and watching for air bubbles. if there is any then that is likely the reason of the truck stalling. often times it is the bleeder screw that is leaking or the seals on the primer bulb.
Dbleo351
Nov 20, 2016 09:34 AM
Diesel_Daddy6.0
Sep 23, 2015 03:12 AM
Cavnar
Sep 9, 2015 07:18 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
