Cummins 6bta 315hp
Old Sep 1, 2015 | 03:15 AM
SimpleMan1301's Avatar
Beer Cummins 6bta 315hp
I've recently installed a cummins 6bta 315hp in my boat. The engine is older (94') and only had 700 hours on it. My first sea trial my tach was maxing out at 3200 rpm. I realized my tach was not adjusted and used a strobe tach to dial it in. Second sea trial it only turned up to 2400 rpm. After a long steam it would only turn 2200 rpm. Changed all fuel filters and ended up running short fuel hoses supply/return into a 5 gallon jug to insure no fuel line restriction. Tested it again and it turned to 2600 rpm for a very short burst and shutdown. Primed it quite a bit and she started again. Pulled off fuel shutoff solenoid and ran it up to 26/2700 and same result she shutdown and had a lot of air in the system. I am almost certain that I am not over propped. From reading threads on here I believe I may have a lift pump issue? Has anyone else experienced this? It starts and runs beautiful but I can't get an accurate WOT rpm.
Old Jan 3, 2016 | 01:06 PM
Stedtfeld's Avatar
I have a boat with 2 Cummins 6BTA m2 and have the same problem in an engine.
Does not exceed 1900/2000 RPM.
I would be helpful to know if you solve this problem.
And if so tell me how.
Thank you
Alejandro Stedtfeld
(from Argentina)
Old Jan 9, 2016 | 02:47 PM
jkidd's Avatar
Diesel Auto Power Premium 3K And 4K Governor Spring Kit - 12VGS3K4K - Diesel Auto Power, LLC and some heavy duty valve springs.
If you have enough turbo/air to spare you can also go bigger in the injectors.
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Sbboozer
Nov 16, 2014 05:52 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
