03 6,6 duramax random heavy smoke
Old Aug 8, 2015 | 04:17 PM
Michael Barone's Avatar
Default 03 6,6 duramax random heavy smoke
I have a 03 Silverado 6.6 duramax, 300,000 miles, truck runs clean, normally no smoke at all, but a few occasions , very random, it will blow white/gray smoke, enough to stop traffic, total flume, power drops to nothing, the 3 times it happened, its was on the verge of a stall, then just as sudden, power picks up, runs good, and after a few minutes, smoke is all cleared. its way to much smoke for a injector to get stuck open,...any ideas?
Old Aug 9, 2015 | 10:25 PM
2500HeavyDuty's Avatar
sounds like an injector issue. does the smoke smell like raw fuel?
Old Aug 11, 2015 | 03:45 PM
to tell the truth, I was unable to smell the smoke, kept driving and hay fever didn't help, but it did not seem dark enough to be engine oil, one thing I left out, I drove for about 3 or 4 miles after I got power back, and I noticed a trail of fluid that I left, I did not turn truck off and went to next stop a mile away and the trail was still there, this time I turned truck off, the driver side is wet from a power steering leak, and that is the only wetness I saw, top of engines was dry, fuel lines looked dry and after restart an hr latter, everything was normal, like I said, smoke was almost white, was in no way antifreeze
Old Aug 11, 2015 | 04:33 PM
white is related to raw un atomized fuel typically from a bad injector, or coolant.
Old Aug 11, 2015 | 06:50 PM
dieseldean's Avatar
fuel control actuator? fragged injector?
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
fivo2fst4u
Jul 2, 2015 06:20 PM
