Diesel Tech Questions
Old Aug 2, 2015 | 08:30 AM
Diesel Bombers's Avatar
Staff Reporter
Information Diesel Tech Questions
Have any questions regarding diesels? We have the answers.
More...
Old Aug 2, 2015 | 09:26 PM
97cummins's Avatar
Old Feb 5, 2016 | 09:46 AM
grandson diesel's Avatar
I have a 98 dodge 12v motor is bad. So I was wondering if a 24v out of a 98.5-02 will work an what all I have to change.
Old Feb 27, 2016 | 03:45 PM
lrmorgan's Avatar
the pumps are different the 12 is mechanical the 24 is electronic so u will probably need engine harness computer and or several of them possibly whole harness cluster so on my recomendation is to buy a wrecked one or get everything out of the same vehicle it all works together that way
Old Feb 28, 2016 | 01:01 PM
Thank u for the info. Think it might b easier to fix my 12v. How do u tell if rings an bearings r bad with motor already out.
Old Mar 8, 2016 | 11:50 AM
lrmorgan's Avatar
you check end gap on rings
Old Mar 8, 2016 | 06:08 PM
Thanks for info. What cam would b good to run for towing an street I do have to go off road down over a hill sometimes it bad .They r a road to go down
Old Jun 28, 2016 | 12:12 PM
towbarman's Avatar
Default Engine rebuild question
Hi
Just rebuilding a 6.2 bored to 6.5l with db 4 pump and super charger
I have broke the plastic part on the oil pump drive shaft and cannot get one in the uk
Is this part essential for the wellbeing off the engine
or is it just a guide to fit oil pump drive ! If i dont fit it would there be any catastrophic problems ?????
Kind regards carl
Old Nov 29, 2017 | 02:39 PM
Stevenquick's Avatar
Good afternoon,
got a 02 5.9 24 valve cummins. It started up fine this morning drove for a few miles and parked. Came back a few hours later and it turned over but only stayed running for a couple of seconds. It did that 3 times and now wont start at all. The past week ive noticed it missed a few times, but just figured might have been a hitch with the fuel. My tuner throws a tps sensor code but ive been told that it could be other stuff making that code. Any opinions would bw greatly appreciated thanks
Old Jun 11, 2021 | 12:36 PM
tbird's Avatar
Default sct flash device
Have a 2004 6.0 diesel with a sct after doing the update on the programmer it will not update truck
sct says its a discontinued item and no longer supported and does not work with my truck funny has worked with it for 6 years previously
any suggestions would be great
Feb 29, 2016 06:02 PM
Mar 20, 2015 08:20 AM
Feb 26, 2015 08:10 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
