Om617 jeep Comanche swap
Old Jul 27, 2015 | 09:00 PM
Free37's Avatar
Default Om617 jeep Comanche swap
I'm swapping the om617 into the Comanche. I would like to upgrade the turbo but I'm not real sure on what turbo or size to go with. I will be running a 3inch straight pipe and would like to turn the fuel up. Thanks for any answers.
Old Jul 27, 2015 | 09:40 PM
Broke's Avatar
Watching!
Old Jul 28, 2015 | 01:50 AM
dieselxj's Avatar
read up on superturbodiesel.com, they have info on the pump and turbos
Old Jul 29, 2015 | 10:57 PM
Free37's Avatar
On the Mercedes car there is a little electric water pump. It connects to the hose for the heater core do you need that for heat to work on the jeep?
Old Jul 30, 2015 | 07:17 AM
Broke's Avatar
Are you sure it's not the heater control valve? Take a picture
Old Jul 30, 2015 | 09:25 PM
Free37's Avatar
Done some reading and it is a heater water circulating pump. At this point I'm try to get everything off the car that I might need be for I get rid of it.
Old Jul 31, 2015 | 08:55 AM
FTE's Avatar
FTE
No, it's just an extra pump for the car's system, you don't need it for your swap.
Old Nov 19, 2015 | 05:30 PM
Free37's Avatar
So I have got the om617 in the Comanche and trying to start it. I have nothing hooked up vacuum wise do I need any vacuum line hooked up to make it run?
Old Nov 19, 2015 | 05:53 PM
dieselxj's Avatar
you only need vacuum to shut it down electrically if desired , and for power brakes and HVAC if equipped; as far as I know.
you will most likely need glow plugs if it is cold, and a very good battery and cables.
have fun
Old Nov 19, 2015 | 06:02 PM
Free37's Avatar
I'm getting a little fuel at injectors it fired off twice then just dies. I burnt up a jeep starter trying to get it running is there something I'm missing?
