Understanding the KSB
Old Jul 25, 2015 | 07:26 AM
Bigfury's Avatar
Default Understanding the KSB
Working on a 5.9 removed from a Blue Bird bus. Installing in a old Dodge (Champion) motorhome. No wires on the motor. Have no idea what sensor to wire the KSB to? Also will it harm anything if it's not hooked up at all? Thanks in advance and have a great weekend.
Old Jul 30, 2015 | 12:15 PM
u2slow's Avatar
You'll have to figure out which version KSB you have. One needs to be energized to advance the timing, the other cancels the timing when energized.
I believe the stock setup works with a temperature switch, but it can be placed on a toggle switch too.
Old Jul 31, 2015 | 05:29 AM
Bigfury's Avatar
Would it matter to leave it disconnected? This particular KSB is mounted remotely. It uses line pressure to go to a port right beside the inlet port for the fuel line. Being it is in a motorhome cold weather starts SHOULD not be a issue. I truly do not understand what the KSB is to do? Thanks for the reply.
Old Jul 31, 2015 | 11:07 AM
NadirPoint's Avatar
It is not a starting aid - merely a pollution control device to reduce unburnt fuel on cold startup. That being said, on active KSB's, they probably run energized most all the time in cold weather. The timing will help with a little better fuel economy in cold weather, but you would probably not notice it and it won't hurt anything either way.
Old Jul 31, 2015 | 11:32 AM
Bigfury's Avatar
Sure is a whole lot of crap over a little bit of smoke. Thank you for explaining more clearly how this works. On the next problem. Have a great weekend.
Old Jul 31, 2015 | 04:17 PM
u2slow's Avatar
Good read here...
Non i/c KSB vs. I/C KSB - Dodge Diesel - Diesel Truck Resource Forums
If its the early one that needs power to keep the timing 'normal' you can take power off the fuel solenoid. Its not a good idea to run the extra advance all the time. Double check, but IIRC, warm-up and higher rpm highway use are where the extra advance helps.
Old Aug 1, 2015 | 09:18 AM
NadirPoint's Avatar
Why not? I know guys who've jumped a tooth on the timing gear to get more timing than is possible with the stock setup.
Old Aug 1, 2015 | 10:29 AM
u2slow's Avatar
I don't suspect its the additional timing that presents a problem - probably more to do with the mechanism and raising the pressure inside the pump. This was the thread that I thought of when I said it...
...VE44 and KSB general info... - Bombed Cummins - Modified Cummins Diesel and Cummins Swap forum
This thread talks about the rpm at which the KSB has most effect, and some dyno results...
https://www.dieselbombers.com/5-9l-r...sb-switch.html
