P2000 NOx Trap Efficiency Below Threshold Bank1
Old Jul 15, 2015 | 10:27 PM
littletex1's Avatar
Default P2000 NOx Trap Efficiency Below Threshold Bank1
I drove out of 350 miles out of town on my 2012 6.7 Cummins, has 111000 miles on it, and when I got to my destination the check engine light came on. Now I have to drive back tomorrow.
Is it something that can wait till I get back and take care of, or is it something that I absolutely must take care of it right away and take to the dealer?
Old Jul 16, 2015 | 05:14 AM
Jet A Fuel's Avatar
Here is all I could find on the P2000 code.
it doesn't appear to be life threatening but I am no expert. Hope this helps!
NOx 1.pdf
NOx 2.pdf
NOx 3.pdf
Old Jul 16, 2015 | 07:52 AM
littletex1's Avatar
Thanks.
The autozone printout they gave me says;
The pcm detected the third heated oxygen sensor signal was greater than the maximum allowable
I don't know if I can still drive it back home 350 miles away, where I can fix it???
Old Jul 16, 2015 | 07:56 AM
Jet A Fuel's Avatar
I would clear the code and then check it again. Are you towing a heavy load?
Old Jul 16, 2015 | 08:05 AM
littletex1's Avatar
No sir, not towing anything.
I'm out of town with family on vacation
Today is last day to go back
Old Jul 16, 2015 | 08:09 AM
Jet A Fuel's Avatar
Clear the code add some lucas to the next tank of Fuel. I don;t think you have anything to worry about just get it checked at home. The oxygen sensor signal will not cause the engine to not run.
Old Jul 16, 2015 | 08:11 AM
littletex1's Avatar
Thank you sir. I'll do that
Old Jul 16, 2015 | 08:15 AM
Jet A Fuel's Avatar
Here is another thread on the subject.
https://www.dieselbombers.com/6-7-li...ode-p2000.html
Old Jul 16, 2015 | 08:39 AM
littletex1's Avatar
I took both batteries positive & negative wires off for a minute or so, hoping to clear code
But, didn't clear it.
Old Jul 16, 2015 | 09:01 AM
Jet A Fuel's Avatar
The oxygen sensor is probably bad or has a bad connection just get it replaced at home.
Here is how the DTC's are tripped and stored. The PCM powertrain control module sets the MIL maintenance light when it sees a sensor or other item out of tolerance.
Here is some reading its pretty dry.
2012 Dodge trip MIL.pdf
