97 dodge 5.9
Old Jul 7, 2015 | 09:15 PM
trd3rdasslt's Avatar
Default 97 dodge 5.9
OK posted a week ago about fuel issue cannot find the post got the fuel issue fixed now wont start has a P1492 code is that something i can fix or need to go to shop. the truck was running just fine and i got up started it and it died right away replaced fuel pump got fuel back to injectors so ran codes that is were i am at thank you for any help
Old Jul 7, 2015 | 10:17 PM
Jet A Fuel's Avatar
you have fuel at the injectors now that's great I am unable to find the code you referenced a code 14 is a map sensor.
Old Jul 7, 2015 | 11:02 PM
here is the information i got
The definition of a code P1492 is "battery temperature sensor voltage too high". It is set if voltage in the battery temperature sensor circuit exceeds six volts. THe cause is either a faulty better temperature sensor, a short to voltage in the battery temperature sensor circuit someplace, or a faulty powertrain control module if the battery temperature sensor and related wiring are OK.
There is no PIP or SPOUT connector to remove to set ignition timing on your Dodge; these types of connectors are found on Ford products. The ignition timing on your Dodge is not adjustable; it is all automatically controlled by the powertrain control module. Rotating teh distributoer will not affect inition timing; the computere will respond by returning ignition timing electronically to where it wants it to be if the distributor is accidentally turned. Rotating the WILL affect camshaft position sensor synchronization; if the distributor is accidentally turned, a scan tool capable of displaying live engine data will be required to reset it to proper position or the truck will surge and lose power at higher engine speeds and loads. The is no way to accurately adjust distributor position wiothout a scan tool.
I hope this is helpful and answers your questions; if so, please click my accept button! thanks!
Old Jul 14, 2015 | 08:28 AM
Jet A Fuel's Avatar
ask.com That is the funniest stuff I have heard in a while. I can't find the distributor on my cummins either. to funny
Old Jul 14, 2015 | 09:23 AM
Jet A Fuel's Avatar
Here is a PDF on the code 1492 dtc-code-p1492.pdf
It is probably not the problem that is causing the no start.
Lets get back to the basics:
There is fuel at the injectors right?
The engine cranks strong right?
Do you have any mods on the truck programmers, injection pump springs, cams ect ect?
Any recent maintenance done besides the lift pump?
mike531
Aug 22, 2015 04:25 PM
elbedonie
May 19, 2015 10:16 AM
wolfriver
Feb 19, 2015 07:18 AM
DSM1988
Jan 25, 2015 07:23 PM
vaio45
Dec 27, 2014 06:04 PM
