fuel issue
Old Jul 3, 2015 | 02:30 PM
trd3rdasslt's Avatar
Default fuel issue
I have a 1997 dodge 5.9 i replaced the fuel pump on side of block but still cannot get fuel to injectors how would i know if the injector pump was bad sorry for such a dumb question 1 deisel i bought good engine 1st time had any problems
Old Jul 3, 2015 | 02:55 PM
Jet A Fuel's Avatar
do you have fuel supply at the P7100 pump?
The injection pump is pretty bulletproof.
just crack all the lines at the pump or the injectors and cycle the key a few times to get the lift pump running you should be able to feel it clicking. If not check your Fuel pump relay.
Old Jul 3, 2015 | 03:04 PM
iF THAT IS THE PUMP FOR INJECTORS NO I HAVE NOT BEEN ABLE TO GET FUEL TO PUMP PRIMED IT ABOUT 100 TIMES
Old Jul 3, 2015 | 03:19 PM
Jet A Fuel's Avatar
yes that is the mechanical high pressure pump.
Here is some diagnostic files.
First can you have someone cycle the key and feel with your hand wether the lift pump is running.
Do you have fuel at the lift pump? I other words is it pulling fuel from the tank?
fuel-ignition-•-injection-•-fuel-pump-relay-•-description-and-operation 1997.pdf
fuel-ignition-•-injection-•-fuel-shut-down-relay-•-description-and-operation-•-fuel-shut-down-re.pdf
fuel-supply-pump-low-pressure-bleeding 1993.pdf
powertrain-•-diagnostic-information-and-procedures-•-general-troubleshooting-•-no-start-tests-•-.pdf
Dbleo351
Nov 20, 2016 09:34 AM
Diesel_Daddy6.0
Sep 23, 2015 03:12 AM
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
moneypitk5
Feb 12, 2015 11:01 AM
