PowerSmoke 6.0 Woes
Old Jun 28, 2015 | 08:03 PM
JFreeman510's Avatar
Question PowerSmoke 6.0 Woes
I'm in the middle of resurrecting one of these 04 6.0L Powerstrokes from the dead. Its been sitting for 5 years, owner parked it due to "white smoke". Did a vacuum test on the coolant system, and decided it was a leaking EGR cooler. Tore it down and sure enough the EGR cooler, intake, exhaust, all full of coolant. pressure tested the cooler off the truck, just for safe measure, leaked like a sive.
Problem is, got it all back together, ran it for about 30 min in the yard and its still smoking white ... My instincts say this is from the pool of coolant that surely exists in the exhaust system.. but I also noticed a white film forming in the oil fill tube, along with very small puffs of white smoke. Not sure if this is normal? Or the truck has deeper issues ...
While i had it running, the coolant res. never hissed, or burped at all ... I hear those are the signs of head gaskets...
I also changed the oil cooler while I was in there. Doubt that has anything to do with all this, but maybe....
Any help would be great, might owe someone a if we solve this !
Old Jun 29, 2015 | 06:14 PM
j johnson's Avatar
silly question...did u by chance change the oil before u started the trk...scott
Old Jun 29, 2015 | 07:32 PM
Yup, Rotella 15-40. I can see there being some water left in the cat that still needs to burn off ... but what would cause the white greasy film in the oil fill tube ? and is it normal for it to smoke a little with the cap off while running ??
Old Jun 29, 2015 | 07:41 PM
j johnson's Avatar
depends on the color of the smoke....if it looks like steam then i would asume that its burning off the contamates in the engine....if its blue then ur burnin oil....scott
Old Jun 29, 2015 | 07:43 PM
Its white smoke, just like it was before the EGR cooler was replaced, except a lot less ....
Old Jun 29, 2015 | 07:48 PM
j johnson's Avatar
i say give it some resonable amount of time and see if it clears....if not then we can go forward from there....scott
Old Jul 2, 2015 | 02:18 AM
j johnson's Avatar
well howed it go!!!
DoctorJJ
Jun 9, 2015 08:07 AM
slowstroke
For Sale
Apr 1, 2015 11:35 AM
scubasteve12
Mar 29, 2015 09:39 PM
thumperf350
Jan 8, 2015 12:55 AM
GWest
Oct 12, 2014 09:22 PM
