no heat
Old Jun 23, 2015 | 03:42 PM
auspot's Avatar
Default no heat
Any time you change or replace the anti-freeze make sure that you turn on the heater full blast
as this will eliminate the air pocket in the heat when you fill the radiator. I seen on here that someone
had no heat.
An ole boy came into a 7/11 store with a heavy coat it was about 20 degrees out and was saying
no heat in his truck. I asked him if he just change the anti freeze he said yes I asked if he had the heater
on full blast and he said no I told him to go home let the truck ;cool off and turn the heater on full
blast start the truck and add some more anti freeze. He had an air bubble in the heater.
hope this will be a help to someone
auspot
Old Jun 30, 2015 | 05:57 AM
05 hd 3500's Avatar
Default No heat
I flushed and cleaned and re did entire system over and over again. Eventually I isolated heater core piping coming out the firewall and there was no unclogging it. Had to bite the bullet and replace heater core. About $80 and was easy to replace. Only problem is I had to take out the whole complete damn interior dash to get to it. I would try to unclog heater core by putting cleaner in core only first.
stripmechanic
14
Apr 6, 2015 09:10 PM
ajwright64
Feb 4, 2015 09:36 PM
DMAX51
Chevy/GMC Duramax 01-04 LB7
Oct 22, 2014 01:39 PM
