92 cummins not charging, no tach, or odometer
Old Jun 20, 2015 | 05:58 PM
Jordon92's Avatar
Default 92 cummins not charging, no tach, or odometer
I'm having some issues with my 92 Cummins 5 speespeed manual. I have replaced the alternator and cps. Has anyone had this problem? If so please feel free to jump and and help out
Old Nov 30, 2015 | 02:25 AM
jdaivs1's Avatar
Did you ever figure out what the cause was? Was it your voltage regulator and was the odometer a separate issue?
Old Dec 1, 2015 | 03:22 PM
u2slow's Avatar
The PCMs will eventually fail... and they are getting scarce to find used.
I'm going to bypass it all when the time comes
"De-computerize your Dodge" - Dodge Ram, Ramcharger, Cummins, Jeep, Durango, Power Wagon, Trailduster, all Mopar Truck & SUV Owners. Dodgeram
Old Dec 14, 2015 | 01:37 PM
23027's Avatar
Sounds like the pcm to me. All are symptoms for a failed pcm. Check terminals and wiring for any corrosion. The pcm is located in the driver side fender near the front
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
tur370
May 17, 2015 04:00 PM
tur370
May 14, 2015 08:09 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
