Cummins no throttle response afer ECM swap
Old Jun 14, 2015 | 10:20 PM
jeremiah1's Avatar
Default Cummins no throttle response afer ECM swap
I have a 2004.5 dodge cummins 3500. build date 7-04. the truck went down with a spun bearing. so I rebuilt the motor. Truck ended up needing an ECM (wouldn't run at all) I have an 05 ECM I put in the truck that I know is Good. It wont command the lift pump on the fuel filter housing so I fed 12v to it and the truck started but has no throttle response at all..?? I thought the 04.5 and 05 ECMs will interchange without issue.. The date on the ECM I installed is 10/04.
Old Jun 18, 2015 | 05:01 PM
Jet A Fuel's Avatar
Hi Jeremiah,
Here are some schematics of the engine control system.
Check for the 5 Volt supply to the ECM. The IPM may be something to look at too.
2004 dodge.pdf
2004 dodge 1.pdf
2004 dodge 2.pdf
dodge 2004 3.pdf
jeremiah1
May 19, 2016 04:58 PM
rusty 6.5
Jun 13, 2015 05:45 PM
Zachbishop
May 29, 2015 07:21 PM
mcclusk
Feb 21, 2015 09:50 PM
PerformanceAuto
Jan 15, 2015 12:32 AM
