Show And Tell Got Photos or Videos of Your Diesel ? - Post Here and Tell Us About it , We Support Most Video Sites , Diesel Videos will Auto Embed .
91.5 W250 resto
Old Jun 9, 2015 | 07:57 AM
ofelas's Avatar
Default 91.5 W250 resto
Hi all,
First Cummins (not my first Mopar though) - work started on it last year.
Started with blasting, powder coating the frame after checking the alignment -
Every body panel was either replaced, or patched & straightened -
Since the motor had just 88k miles on it, just some minor valve adjustment, and a few fresh gaskets/seals, along with checking bearing clearances -
New floor panels, roof skin & reworked rain gutters, then everything primered/sanded multiple times, and sprayed with Eastwood's SubLime urethane enamel + top coat clear -
Interior was restored, bombed and all connections cleaned & Ox-Garded -
New carpets, door membranes, panels, interior trim & seat reupholstered -
Old Jun 9, 2015 | 07:58 AM
ofelas's Avatar
part 2
All braking components the transfer case & axles were rebuilt with NOS parts (OK, the front pads are PFC carbon metallic)
Spicer Life U-joints all around after balancing the driveshafts. NOS springs & mounting hardware went on next.
The tranny was rebuilt with Red Eagle/Kolene & a slightly tighter converter. A Transgo shift kit was installed, and the system refilled with Amsoil's Synthetic ATF.
Motor was run on some decade old Amsoil 15W40 and a Fleetguard filter for a while, then drained & refilled with Amsoil HDD 5W-30 & an EaO filter.
Diffs & NP205 got fills of Severe Gear 75W90, and the cooling system got a Cummins double jiggle pin stat + Mopar HOAT in an NOS radiator, with a factory clutch & fan.
Dayco tensioner assembly + Dayco Gold Belt went on next - I see I will spend more time with a 1/2" drive on this motor.
Bilsteins all around -
Homebrew bedliner - 6 spray cans of rubberized gravel guard -
5 year old Interstate gave up this winter, so a 1150cca Odyssey went in with ring terminals all around -
Some bling went on when I was salvaging the parts bins for my 81 W150 -
Gotta break up the 6 acres of SubLime -
Not many mods so far - just a wastegated 14cm housing with a Banks BHA; used brake line routed along the firewall to plumb into the drivers side intake -
It's been my daily driver since Christmas, liking it so far.
Going to install gauges as I'm curious what it runs at before I start fueling it.
Old Jun 9, 2015 | 08:00 AM
ofelas's Avatar
Dumped in a pair of Trucklite LED headlamps - here's a frontal next to the F350 I picked up last week.
Old Aug 18, 2015 | 12:26 AM
Notdaddysmoney's Avatar
Mad clean man. Love the sub lime. 😎 ready to get me a first gen!
Mar 23, 2015 08:10 AM
Tucker126
Jan 2, 2015 08:09 AM
wvwelder89
Nov 20, 2014 10:26 AM
95xtracab
Nov 12, 2014 05:54 PM
Darrin-ky
For Sale
Nov 8, 2014 10:30 PM
