Bleeding Air From PS Pump on 2004
Old May 16, 2015 | 08:23 PM
scottw1513's Avatar
Default Bleeding Air From PS Pump on 2004
I just installed a new PS pump, and I have been trying to bleed the air from the lines for two hours now with no luck. Is there a certain procedure, or could it be a faulty pump?
Old May 16, 2015 | 10:32 PM
South Texas Goat's Avatar
With the engine off, tires off the ground, roll the wheel from left to right until it bleeds out, engine on and pump running will get air carried thru the system
Old May 16, 2015 | 10:52 PM
dangerous1965's Avatar
Every time I changed one out I filled it ran it and checked the fluid level! Are you getting hard spots when turning or hitting the brakes? It's a self priming system no bleeding needed!
Old May 17, 2015 | 08:30 AM
Self priming yes, self bleeding, not so much. You should always turn it lock to lock with engine off to get the air out, you have been lucky to not have any issue.
Old May 17, 2015 | 09:41 AM
Probably because the system was already full I just changed the pump!
Old May 17, 2015 | 11:20 AM
scottw1513's Avatar
I have tried turning the wheel lock to lock with the tires off the ground. I tried it for about 30 minutes with the engine off, and its still stiff lock to lock, and the brakes will only press about 1" down.
Old May 17, 2015 | 04:12 PM
There should be no more air, when the truck is on the pedal should drop a bit then push back. Is the hydroboost whining? I had to change my steer pump twice, the first one leaked right out the front seal.
Old May 17, 2015 | 04:26 PM
scottw1513's Avatar
There is no whining. I'm starting to think its a faulty pump. $350 for a pump, and still having problems.
Old May 20, 2015 | 06:56 AM
scottw1513's Avatar
Just a update. The pump was faulty. I got a new one from the stealership. The system is self priming, and I didn't have to bleed air from the lines. Thanks for the help.
moneypitk5
Feb 12, 2015 11:01 AM
dawnrogerl
Price Quote - Request A Price
Jan 29, 2015 01:03 AM
airspeed181
Jan 19, 2015 09:00 PM
Anh Chà n
Jan 9, 2015 12:45 PM
veggyoilkid
Nov 10, 2014 12:39 PM
