voltage regulator problems??? need help!
Old Apr 27, 2015 | 01:32 PM
91firstgen's Avatar
Default voltage regulator problems??? need help!
hello. ive got a 91 intercooled cummins and been having troubles with my voltage regulator. ive changed my regulator a couple times now,went through all of the wiring,checked plugs even changed the altonator and cannot seem to find the issue. it seems to work fine for a month or so then regulator fails again and causes over charging of the battery...PLEASE HELP!!!!! has anyone had this problem before???
Old May 2, 2015 | 01:07 PM
Begle1's Avatar
Try getting a different brand of voltage regulator.
I went through about three of them before I finally got one that stuck for years since.
I did put my field coil in the alternator on a dash switch so I could just turn the alternator off when the voltage regulator went out and started charging at 20+ volts.
john grossman
10
Jan 12, 2019 08:58 PM
Saams69
Jul 20, 2015 11:21 PM
klein444
Jun 20, 2015 11:48 PM
robbyS
Apr 16, 2015 02:22 PM
Big _red _cummins
Nov 17, 2014 02:44 PM
