Wrench light
Old Apr 26, 2015 | 05:48 PM
shawnecarter's Avatar
Default Wrench light
07, F350 SD 6.0 turbo diesel just turned 300K
I was just about to cross the Florida Georgia line when the wrench light came on. I stopped at the welcome center and started checking things out. manual says its the throttle control sensor, limp home mode. Get it to a for d dealer asap, as if.
Called my nephew and talked through several options.
Disconnected power and it cleared the wrench. Still hasn't come back. Service engine light is on, I do need to get that code read,but not possible at this time on a Sunday evening.
The problem that this has left me with is; my fuel consumption has bottomed out. Burned over half a tank in 101 miles. Throttle reaction is good, only had one noticeable "chug" episode when I had to slow down significantly for a weigh station. Idles well, nothing noticeable there either.
I have been told clogged filter. Sensor itself. Even a bad glow plug or two.
Can I et some help?
Thanks
greenbomb
Chevy/GMC Duramax 04.5-05 LLY
Feb 18, 2018 07:55 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
yams
Dec 7, 2014 12:51 PM
