5.9 Turbo oil return line
Old Apr 18, 2015 | 10:34 PM
CumminsCoalRoller24/7's Avatar
Default 5.9 Turbo oil return line
Noticed that my oil return line directly under the turbo was saturated- not leaking real bad but noticeably black when installing my new A/C compressor. Dealer had a gasket for $7.79. It is easy to access from underneath with an extension but I was wondering how much if any oil will come out after disconnecting it? Should I wait until I change my oil and have it drained? Any wisdom would be appreciated!
Old Apr 19, 2015 | 02:11 PM
AHolt's Avatar
There wont be a lot.
Put a pan under it and catch the little that comes out.
Old Apr 19, 2015 | 03:47 PM
Bigg Redd's Avatar
Maybe a couple of ounces....if that.
Old Apr 19, 2015 | 10:06 PM
dangerous1965's Avatar
Nothing will come out that's a DRAIN Gravity nothing to stop it. Unless it's running when you take it off! Remember the other end has a o-ring.
Old Apr 21, 2015 | 09:03 PM
Thanks for the help! I Let it sit in the driveway for about an hr before I removed the bolts. There was no gasket on my return for some reason. Now there is and all cleaned up!
avatardvr
18
Aug 8, 2019 12:38 AM
honda89
Oct 17, 2015 01:08 PM
rodbuilder
Jun 26, 2015 12:48 AM
|WYG|SS
May 7, 2015 04:57 AM
MrCat4974
Mar 25, 2015 08:13 PM
