A/C blows warm
Old Apr 10, 2015 | 12:42 PM
CumminsCoalRoller24/7's Avatar
Default A/C blows warm
Bombers,
I have an 06 5.9 a/c was blowing warm after a recharge so figured compressor was shot (it has 185k on it). This is last Friday I replaced the liquid line with orfice tube, accumulator/dryer, and compressor all in one shot. All new parts. Took it to the dealer after for a system evac and recharge. Worked great through Wed evening my a/c was fine. Thursday morning truck was blowing warm air again, I stood in front of if running with ac on full blast and couldn't hear the compressor engaging. I'm guessing that means I am leaking freon somewhere? Help!
Old Apr 10, 2015 | 07:37 PM
AHolt's Avatar
Sounds like a leak.
Buy a can of freon with dye in it, recharge and look for leak.
Old Apr 12, 2015 | 04:46 PM
I hooked up a can of full freon with dye today- after putting the hose on it immediately jumped up to the green range full where it should be. I also pulled dash to be sure it was fully connected behind ac button. Lastly ran my obdII reader and no codes or soft codes checking with cycling key. Off to get voltage reader.
Old Apr 17, 2015 | 08:38 PM
There was a leak, the dang o rings that came with my compressor allowed the high and low pressure lines to seat but not air tight. Easy fix but aggravating
Old Apr 24, 2015 | 07:34 PM
A/c started blowing warm again- yesterday I had the air control on cold the other day but a/c off on my dash- there was a lot of water coming from the passenger side - enough to make me wonder if I ran over a water bottle or something. Engaged my A/C today and won't blow cold- any ideas?
Old Apr 25, 2015 | 09:55 PM
Un4givn's Avatar
It could be the temp adjust **** on dash going bad just a thought
Old May 3, 2015 | 08:22 PM
A. Netto's Avatar
Hey everybody im new dodge ram2500 cummins owner and today I change my AC compressor thinking that's my be the problem and still not working, please if know some thing to help let me know
I appreciate
Old May 5, 2015 | 08:55 PM
Sorry to hear youre in the same boat I was- did you replace just the compressor? Did you check system charge? It was reccomended I do compressor,liquid line ( contains orfice tube), and accumulator/dryer. Drain entire system then recharge
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Maclain Marsh
Jul 13, 2015 06:23 PM
cooler364
Mar 26, 2015 10:58 PM
sjcdep08
Nov 12, 2014 07:05 PM
Stick_Welder
9
Oct 24, 2014 04:10 AM
