Bad MPG, injector light keeps coming on.
Old Mar 28, 2015 | 01:18 PM
Smokin Joe's Avatar
Default Bad MPG, injector light keeps coming on.
At best averaging 16 MPG my injector light comes on frequently while driving. Dealer mechanic said is just because running to rich. I need to desperately improve MPG. I Drive a lot and spend a fortune. Single dad with 3 kids and need to save all I can. Please help.
Old Mar 28, 2015 | 10:16 PM
dangerous1965's Avatar
Buy a TDI! You need to list you mods and what you got! 16 around town is good never heard of running to rich!
Old Mar 28, 2015 | 11:09 PM
cerberus60's Avatar
What injector light, there isn't one. If you mean th egrid heater light you have a leak in the fuel system somewhere, likely injectors.
If you want to fix it that will cost money. You might be better off with a cheaper gas car if you have money issues. These trucks are not cheap to run, repair, etc.
Old Mar 29, 2015 | 08:44 AM
Smokin Joe's Avatar
Thanks for reply. As anyone can tell I'm new to this animal. What is a TDI? The truck is bone stock in exception of running 35's on a set of 20" rims and dual exhaust from muffler ending with 4" exhaust tips behind back tires. Injectors were all redone at dealer and I took it back once to have them look into the egrid heater light coming on all the time after it almost stalled on me. They replaced lift pump and told me it's just running too rich. Light still comes on and has almost stalled once more since then. Codes mentioned #4 injector and bad fuel feed. No signs of fuel leakage along rail or injectors. I don't trust dealer mechanic anymore. So here I am . I was told from multiple sources that I should be getting 20 mpg. Maybe with stock tires. I understand I need a 4 cylinder car. Always wanted a truck like this and now one step closer to that boat been dreaming of too . So just trying to get by the best I can for now.
Old Mar 29, 2015 | 09:46 AM
cerberus60's Avatar
The 35's aren't helping the mileage in town, will help on long cruises at roads speeds though. They are also more than a bit hard on the transmission. The 16, if that is a normal mix of driving is consistent. You won't see 20 unless it is in good conditions on long stretches. What engine you have will impact that also, 04 had 3 engines with different programming and operations. The the 250 and 305 were early engines, the 325 a late engine.
Your dealer did you no favors with injectors, they are some of the crappiest remans in ciculation. In addition, your dealer techs are a bunch of bumbling idiots when it comes to diesels. They have obvious codes and problems and their response is "it is running rich", not even competent for oil changes from the responses.
The ECU calculates fuelk leaks by comparing estimated fuel delivered by the FCA compared to fuel used based on duration adn pressure of the injection events. When those numbers are out of balance it sets the codes and grid heater light. These leaks are internal high pressure leaks of injector bypass, over injecting fuel, and possibly an FCA malfunction. The stalling indicates an FCA malfunction. You might get lucky replacing it but with a specific injector code like that it won't solve all the problems.
Old Mar 29, 2015 | 10:28 AM
If it costs nothing but your time and headache have them replace the #4 injector. Then find a Cummins shop in your area!
Old Mar 29, 2015 | 12:18 PM
akhappyjack's Avatar
could be something as simple as a nicked injector oring but yes your better going to a non oem injector get rid of the 35s it is hard on a stock trans,as for the dealership techs the quality now a days is sadly lacking it's bad when I know more than they do
bbilt
5.9L Rotary Performance
May 29, 2015 07:05 PM
Jake12valve
May 10, 2015 11:57 PM
Jan 14, 2015 03:40 PM
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
Nov 29, 2014 12:40 AM
Omingnome
Oct 20, 2014 12:25 PM
