6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
2005 ford 6.0 no start
Old Mar 18, 2015 | 12:35 PM
keith63's Avatar
Default 2005 ford 6.0 no start
Need some help please on trouble shooting/repair. No Mods vehicle is a stock F-350 with 110k miles. I am original owner. I installed a 9'2" boss plow on vehicle upon purchase of truck.
While driving (snow plowing) the engine shut off as though I turned the key off, no warning had plenty of power.
Using a snap on modus scanner
-ICP reaches desired 1500 PSI plus. I did unplug for default still no start.
-IRP starts at 15% and ramps up to 85% then drops down to 45-55%. IPR was replaced approximately at 100k miles on vehicle.
-ficm input voltage 12.5 v
-ficm voltage 48.2 and at cranking stays above 48 volts
-ficm sycs
-ficm was replaced around 95k miles, due to failure low voltage.
- checked ground wire from ficm to left rear corner of intake OK.
-Fuel pressure at test port 62 PSI, filters good.
-bubble test and balloon test done, no pressure push back found.
-Buzz test all injectors click good.
-checked all body grounds OK
-Engine cranks and occasionally fires a cylinder or two but will not start.
I have checked wiring to both cam and crank sensors continuity is good no grounds. Ohms across at PCM wiring harness to each sensor both with in spec. I live in Northern Michigan and have found cam sensor pushed out from rust and salt build up, I have removed both sensors and check for this problem OK.
Any feed back would be greatly appreciated, (frustrated)
Thanks,
Keith
Sep 15, 2015 07:40 AM
Cavnar
Sep 9, 2015 07:18 PM
ish1521
Aug 26, 2015 08:42 PM
Apr 16, 2015 05:39 AM
cjgregory
Mar 31, 2015 01:45 PM
