need help asap rouph idle
Old Mar 14, 2015 | 01:15 AM
canigeta727's Avatar
Default need help asap rouph idle
asap rouph idle
Im in need of help bad bought a truck YESTARDAY its an 05 cummins 2500 have have 3 first gens and one 2nd so im new to the common rail. I.picked up truck ran great throughout the day my bat gauge went to zero the kid had subs and a light bar wired in. I was driving home and the truck started sputering the truck then threw an engine light followed by all the lights in dash turned on abs, brake the radio cut off and I took it to get pluged in it through 9 codes all being power related it then barly ideled and when turned off would not turn back on without a jump and when it did it ideled poor. on way home it would not go over 30 finaly shut off I replaced newer batts and unwired his janky subs and light it seemed fine drove home parked it and came out this morning and started it still had engine light on and I noticed somthing new it was smoking a lot of whiteish blue tinted smoke the engine light went away after a little time and the bat gauge came back to about normal I.believe the altenator is junk truck has about 226k on it and is stock no chip truck currently starts but has a rouph smoky idle injectors right? But a month ago the old owner had injectors replaced soooo anyone that can help is a huge help can it be the alt or low power did it having low power do damage to new injectors or is it something diffrent please bring me good news
Thank you
Old Mar 14, 2015 | 11:09 AM
Nothingggg?
Old Mar 16, 2015 | 09:06 AM
dangerous1965's Avatar
Clean all your grounds! What codes does it have now? New injectors or rebuilt? Do you have the receipt? Rebuilds can take a crap out the box! Check for blow by!
Old Mar 18, 2015 | 05:00 PM
Bigg Redd's Avatar
Also, clean the electrical connector(s) at the CP3 injector pump. lube with di-electric grease before you reconnect.
GT_Eleanor
Aug 25, 2015 09:35 AM
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
