Cummins conversion brakes
Old Feb 25, 2015 | 09:47 PM
Chummins80's Avatar
Default Cummins conversion brakes
Hi I'm doing a conversion into a 1980 chevy. I need help with the brakes the cummins has the vacuum pump on power steering pump, when I hook up the vacuum line to the chevy master it sucks the the peddle to the floor and when I take the vacuum line off the peddle comes back up. I don't know if the booster is bad or the dodge vacuum pump has touch vacuum. Need help!!
Old Feb 26, 2015 | 11:18 AM
novapat's Avatar
I am going to say a bad booster.. on my suburban with a cummins 12 valve and the later vacume pump to the stock booster mine work great! good luck!!
Old Feb 27, 2015 | 12:36 PM
cumminsblazer's Avatar
My blazer works great also must be the booster do you have a check valve on the vacuum line idk if that makes a difference cause my blazer already had one so kept it in place
Old Feb 27, 2015 | 09:11 PM
Chummins80's Avatar
I don't have a check valve I can try that. Thanks for the help
Old Feb 28, 2015 | 08:34 PM
novapat's Avatar
ya mine has the check valve in that plastic elbo that pops into the grommet on the booster. works great
Radioking1777
Jun 8, 2015 10:26 PM
RedChevy44
Apr 21, 2015 05:47 AM
mt grizzly
Diesel Engine Conversions
Dec 31, 2014 12:13 AM
gixxerman1000
Nov 2, 2014 07:53 PM
Oct 24, 2014 04:40 AM
