INJECTOR ISSUES?
Old Feb 23, 2015 | 08:45 PM
19TIGERS68's Avatar
Default INJECTOR ISSUES?
2006 Dodge, running fine then started smoking, un-burned fuel, running ROUGH and shaking. Dodge stealership replaced injectors less than 65,000 miles ago. Lift pump working, replaced fuel filter, cleaned check valve coming out of fuel pump, and replaced Fuel Pressure Actuator/Valve on back of pump. Easy stuff done, still no change. Ohms tested injectors, # 6 tested bad, replaced # 6, still 'missing" and smoking. I still think it's an injector issue, but other than a shop, how can I tell? Any ideas, I'm not wanting to replace all the injectors as a "troubleshooting" method.$$$ Also, if anyone knows of a GOOD diesel shop in the Greenville, SC area let me know, I'm so sick of the Stealerships.
Old Feb 27, 2015 | 09:36 PM
jkidd's Avatar
Hi, We can test the injectors for $30 each. Low quality remans can be bad out of the box. You might have a bad cylinder. Testing each injectors will help isolate the problem and you can get a boroscope to look in to the cylinder.
